Overdrive Problem
Als Surf
]Help!! Ive just spent £400 on having a gearbox solenoid changed and valve body pressure done etc to try and cure my problem - It wont go into Overdrive but other gears work fine, as does kick down-someone has suggested TCU but is it more likely to be a rellay - if so where the hell is it!! - Thanks and and replies appreciated
Why do you say it won't go into overdrive???
Overdrive is only 4th gear.
Hi Al
I had the same problem earlier this year, I spent the best part of £2000 having the gearbox re-conned, every solenoid replaced, clutches renewed, hire cars,etc etc, only to get it back 3 weeks later still with the same problem(the only thing i got from the re-build was an expensive 12 month warranty)
I then swapped the ECU from my other surf and b*gger me,it solved the whole thing. After spending another couple of weeks searching for an ECU with all the matching part No.s. I dragged my way thru eblag to find one,,,,, It worked out cheaper for me to buy a whole vehicle just for the ECU and then break the rest.
I eventually made a profit on the breaker.
So my friend, I believe your problem lies in the ECU
Cheers
Paul
Was the speed sensor checked?
Is the ETC button pressed in?
Hi Al
Cheers
Paul
Hi Dont know if you got my last email - can you tel me whether you got a new ecu or a auto tcu and wher abouts in the car do i find it. Thanks
The ECU is on the passenger side behind the plastic panel near the door.
