Drive Shaft Gator Rattle
Miss T Sport
Hi need advice / previous experiance.
Well as some of you know i recently had a new lighter f/w and new header fitted.
Well all went well fitting wise apart from one annoying problem
The rubber gators that go on the drive shaft are now loose and knocking against the gear box.
The sound is worse then what is actually happening. The garage that fitted the stuff are baffled as to why the gators are now loose and wont seemingly go back into the correct position.
I am going to contact Toyota about this, maybe there is a factory process that they do to compress them back in.
Has anyone else had their gearbox taken out for any reason and if so have they experianced this problem.
Cheers
Teri
