Knockin At 3500revs
NickL
Hi all, this is my first post so sorry if its one asked a lot but i cant find it anywhere,
i drive a 140 celica yr2000, super high mileage (143k) it all seems good condition, i'v been keeping a close eye on the oil as have read others problems with that, but i seem to get a knockin noise from the engine at about 3500revs mainly in 3rd gear.
any ideas what it could be?
also i v rarely rev my engine any harder then about 4500revs before changing gear, is this good or bad for the engine?
sounds like big end bearing knock,i had the same noice on my mr2 roaster(same engine as celica 140).not good
oh dear, not what i was hoping, how bad is not good? expensive?
If it is that, its an Engine out job, so already quite expensive (£1k +, depending on where you go)... I'd get it properly diagnosed before you start to panic though.
If you were constantly in the 6.5k RPM mark then you're going to be unduely stressing the engine, 4.5k is closer to normal operating, and only 0.5k RPM since the VVT kicked in! I think you can quite safely wait till 5.5k or higher before you change gear (assuming you're engine is all ok, obviously - get it checked out first!!), and you can then enjoy the engine a little more... They'll happily take a good thrashing every once in a while once they've warmed up a bit!
cool thank you for the advice, its due and MOT and service soon so will get it checked out by the trusted garage i always use.......fingers crossed for some good news
if it is the bearing add 2 tins of stp and sell it on. :o :o :P
Does it do it all the time or just when you put your foot down?
just when i speed up, even just regular acceleration makes an unpleasent sound, not tlkin about foot to the floor stuff
have you had the car looked at yet,i wouldnt keep driving it until you have.does it do it on idle?
  • 3 months later...
probably the slowest reply in the world. but better now than never!! lol
naaa it sounds fine on idle
I would get it checked out,could turn out to be something else(heat shield etc),a good mechanic should be able to listen to your engine and tell you if its bottom end knock or not.
