St202 Suspension
mujaddid
Hi All,
RElatively very happy with my new celica GT 1999 UK Spec 40K 1 owner :D
However I am not very happy with the suspension and was wondering if there are any part wich should be changed for a car of this milage,
Link rod, trackrod ends etc any advice is appricaited but compared.
NB: I need new tyres and discs pads all round.
Hi All,
sort the house before rearranging the furniture.
No knocking sounds, just seems somewhat wobbly (cant think of better way to describe it) ?
TIA
Also is there a definitive list of service parts that should be used oil type etc?
TIA
Is it too much body roll or is it too soft/bouncy? Lowering springs? If thats not enough, stiffer or adjustable shocks. Check the anti-roll bar is in tact and replace the anti-roll bar bushes. The bushes are pretty cheap from toyota, as are the roll bar drop links from TCB or eBay.
When I had my Celica, I just had lowering springs, new drop links and bushes. The handling was pretty excellent round Nur, could have done with a global alignment for perfect stability though.
Points noted, there is however a strange lack of body roll especially when transitioning to higher gears, jerks back (hard to describe). but this could be due to sticky caliper or brake realted.
