Yaris fast idle
tallpaul
When it's cold outside, but the engine is well warmed, my 1.0 Yaris idles faster than norm, around about 1000rpm.
If I dab the throttle, it'll drop back down to normal again. At the next set of lights, the whole game starts again.
Any suggestions as to what's causing this ?
It doesn't happen all the time, just occasionally.
Cheers, TP
  • 2 months later...
Things driving the alternater will make a difference. In the cold you will have your heaters on which would cause a higher idle level.
