Steering Wobble
TIFFY
THIS IS MY FIRST TIME ON HERE SO SORRY IF IT DOES NOT MAKE SENSE! I HAVE A TOYOTA ESTIMA EMINA M REG 2.2 TD 2 WD IT HAS JUST STARTED WITH A WOBBLE IN THE STEERING AT ABOUT 10/20mph THE WOBBLE GOES AFTER 20 mph AND WHEN STOOD STILL WITH FOOT BRAKE APPLIED THERE IS A VIBRATING NOISE AND VIBRATION COMING THROUGH STEERING WHEEL AND PEDAL WHEN GOING INTO LEFT HAND LOCK PLEASE CAN ANYBODY HELP THANKS
Hello and welcome to TOC :thumbsup:
That might be difficult to diagnose without physically seeing the vehicle :unsure:
Have you checked that the wheel nuts/bolts are fully tightened?
Are your wheels running straight and true? (i.e.........not buckled)
A trip to a decent tyre fitting specialist may help solve the problem.
Good luck and let us know if you find out what is causing the problem :thumbsup:
(Please take the CAPS LOCK of your computer as this has been known to upset some of our members when people "SHOUT" on here :) )
thanks for your reply tried all that you said but none of that has worked!
It may be time for the specialist tyre firm to take a look then
