Replaced Maf And The Engine Management Lights On :s
sphinktar1988
got a brand new toyota Mass airflow sensor
replaced mine to see if its what was causing my "powerless car"
started the car up and its running a lot better but the engine management light is on :S
any ideas?
any ideas?
Dint change it with ignition on by any chance did yer? If so the code will want resetting
ahhhh my mate was there when i did it and he said what happens if you have no MAF so i started the car with it unhooked
im sure i switched the ignition back off but i cudnt say 100%
will the old "take the Battery off for 20mins" trick do it?
will the old "take the battery off for 20mins" trick do it?
Yeah starting the car with it disconected wil deffo put a code up and the MIL light on. Dont know if dis-connecting the Battery will clear the code i`ve never personaly tried it. If it dont, and you have to take it to the garage, tell the truth about what you`ve done. It will save loads of the tec`s time and you`l probably get it done cheaper.
went off itself :D oh andddddddd FLAT SPOTS GONE :D
im proper chuffed
just need the rattley clutch out now lol
and get the tsport bumper on :)
cheers for the advice
