Tyre Pressures
vitzpower
I've got an imported ST205 GT-Four with the factory 16" three spoke alloys. What should the tyre pressures be for the front and rear tyres?
it should be on a sticker , drivers door slam post.
32 to 34 psi is a good choice , all round , depending on load etc.
Or a sticker in the glove compartment.
I'd also agree with Booster's guesstimate; it'll depend on tyre size, but will be there or thereabouts.
Though possibly slightly more air required in the fronts vs the rears given the exta weight of the engine over the front wheels.
But if you start with 32 or 34, see how it drives, and adjust accordingly you won't be far out.
As a precaution, keep a check on tyre wear - edges wearing = pressure too low, centre wearing = pressure too high.
