2001 Toyota Avensis Gs D4-d Diesel
help my bob
I am thinking of buying the above Toyota, it has 73,000 miles on the clock, what should I look for, what would the expected MPG be, and do they have timing belts or chains, any advice before taking the plunge would be appreciated, thanks
D4D...
2001
expect Above 40MPG and below 45MPG
Belt driven / Cam belt needs to be chnaged at 60k.
Dual Mass Flywheel can be a problem, it all depends on how the car has been treated.
Symptoms are
1) ticking / knocking noise at startup and under heavy load (you will only hear it when you have the windows down)
2) vibrations through the clutch pedal.
Thats the major one to look out for.
Check service history,
Check to see all body panels line up
Check Oil level/colour
check radiator coolant
check oil cap colour and smell.
Check over speedbumps and listen for knocking noises underfull lock.
Check undercarriage..
Check for oil leaks, on the inside of the undercarriage.
- apart from the flywheel problems the d4ds are very good car, nothing really goes wrong with them
and remmber do a HPI check.
edit. gearbox is chunky/clunky... on the d4ds but will go in gear everytime. first time.
D4D...
2001
Symptoms are
Thanks for that info, I take it if the flywheel is faulty it will be an expencive job, for a replacement, or was there a recall for this problem
D4D...
2001
Symptoms are
expensive part.
will cost about 800£ including PARTS and labour
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
