Coolant Loss
I have a 94 camry 3.0L v6 which since i bought back in july this year from e-bay,has had problems with the cooling system.Previous owner had radiator and pressure cap replaced and thought problem solved. I've had had a new water pump and cooling fan ecu fitted,but found that it still pushes coolant into resivoir tank which then overflows(after driving for approx 60 miles). I have taken out the thermostat in case that was sticking closed but just done a 65mile round trip and just before i got home noticed the heater went cold and when checked underbonnet found it is stills pushing the coolant out HELP anybody got any ideas.
Ordered and fitted genuine Toyota pressure cap as everything else changed.Now seems to be ok.level going up/down in resivoir tank as per engine temp,no build up of pressure.sorted :D
