Batteries
widebody
Can anyone help?
I need two replacement batteries for my 3.0 Hilux Surf 1994, found some on Roughtrax but they won't deliver (acid not good if split), I have spoken to Halfords - No Good, and Toyota say they can't get a strong enough replacement.
I'm in Suffolk, any ideas?
Halfords do sell them , just note the amps the batteries are and get any that are handed and fit the spaces . the bigger amps the better
Can anyone help?
These are the Toyota part numbers ......
Drivers side UGCGBA3072
Passenger side UGCGBA3073
p.s. The dealer you went to is talking bo**ocks!!!
Name and shame the dealership!
  • 2 months later...
VARTA BLUE dynamic 570 413 063 2082
Product line ------------------ BLUE dynamic
Voltage [V] -------------------12
Battery Capacity [Ah] -------- 70
Cold-test Current, EN [A] ----- 630CCA
Length [mm] ----------------- 261
Width [mm] ------------------ 175
Height [mm] ----------------- 220
Hold-down Type ------------- B01
Pole Positions ---------------- 1
Terminal Type ---------------- 1
Left Battery (passenger side)
VARTA BLUE dynamic 570 412 063 2082
Product line --------------- BLUE dynamic
Voltage [V] ---------------- 12
Battery Capacity [Ah] ------ 70
Cold-test Current, EN [A] -- 630CCA
Length [mm] ---------------- 261
Width [mm] ----------------- 175
Height [mm] ---------------- 220
Pole Positions ------------- 0
Terminal Type -------------- 1
Go to any dealer, get the amp hour capacity off them and thats it, just pay for them :D: To be fair there are a few types but your dealer will be able to sell them. They are correct about being unable to post them, you cant post anything with a hazard label on them these days!
Kingo :thumbsup:
