1991 Levin Gt Apex, Help?
levinGTapex
hey guys, im new to the site,
just purchased a 1991 levin, gt apex, AE101 model
with the 4age engine in
wondering whether i could get any info from some car engine gurus here
engine goes well
and happily does 190kmh, (not that i make it an effort to exceed 100)
but on start up there is a strange, small tapping noise
now i know what it is because i have had similar problems with the nissan engine sr20de
But wondering how similar it is with the 4age?
will a engine flush get rid of it ?
are there oil railings going over top of the cam that i could clean out?
i havent taken rocker cover off or any thing,
surely others might have run into the same problem
is this serious for the invincible 4age engine?
any info would be good
Cheers !
Do you mean on idle? generally the injectors are quite noisy!
quite possibly, what sought of noise should i be hearing from them,
i know due to wear and tear the tappets are probably worn
but i do hear a loud rattle from behind the injection system,
i hope thats wear the rattle is coming from
and yes generally its in idle, also sometimes low revs
on another note, let say i keep maintaining ma 4age engine,
oil changes, engine flushes etc
its done 260 000km, (163 000 miles)
is there any signs that i should look out for, for a engine on its way out ?
any typical problems for the silver top 20 valve 4AGE ?
