Sub Wiring Help
Cobb R
Is there any other way of getting the power supply from the Battery to the boot without going throught the glove box into the wheel arch and into the engine bay. Surely there is another way directly into the engine bay?
Cheers in advance
find out how the rest of the wires lead to the engine bay...there has to be a way, and as for the rest of the car, what i have done with all the cars i have ever worked on is, feed the wire up under the plastic trim that runs along ur doors all the way under the back seats and out a wee hole there...i swear only u would know its there...sometimes it can bee footery tho...
PLUS word of advice ALWAYS use a fuse between the Battery n amp. i always use a glass one for the people cars i do...at their expense of course...
There's a grommet behind the Battery where cables run in to the passenger compartment. It pops out just behind the aircon unit (big white thing) behind the glove box.
I had to take my aircon unit off to get stuff through there, but it may be possible without. I just wanted to make the cable run easy. And I had to re-use a metal coat hanger to force things through the grommet, as its quite a tight hole and just shoving cabling through won't work...
Good luck! ;)
