hey fellas
im currently doing my first service on my 1990 sv21 camry.
its my first toyota. Im kinda stuck in the middle here, i cant find tha fuel filta......i searched other threads, but they only had 95 camry fuel filter is it the same?? its hiding from me.
Also i have a problem with using oil, sum1 suggested to me to check the oil pressure switch because it may be leaking, i cant see any leaks but they reckon while running it will just spray small amounts out at a time..correct? or is he pullin my middle leg? Where abouts is the oil pressure switch located as well?
i would go get a manual, but i have no oil in my car atm so im kinda stuck.
cheers guyz
orrite, ive found where the oil is going, i have a leak at the back of the engine between the head and the block, reason i cant see any leaks is because i travel long distances to work and back and before the oil has a chance to leak its getting hot and burning. so thats 1 down. Would it be the head gasket that has the leak? or is there another seal?
cheers fellas
whoops
The fuel filter is normally located low down on the bulkhead/firewall.
Trace the fuel line from the Injector Rail back towards the bulkhead
