Dump Valve
moulty3
hi im am new to the turbo engine as this is my first just got a 1996 uk model 65000 on the clock with full toyota history,i have put a induction kit on and my factory dump valve is playing up so i have got a baileys dump valve but would like some instuctions or even better some pictures to help me on my way
because the instructions with it are useless
thanx
thanx
Have you got an inclosed induction kit, if not make an inclosure or don't use it and keep the stock air box and go for a TRD or similar panel filter.
As for the DV should be fairly simple take the stock on out block over the hole in the air box or induction kit if it has one then connect the big port on the DV to the big pipe coming from the ChargeCooler(The big black box on top of the engine) and then connect the small vaccum tube to the small port normall on the top of the DV.
