Lack Of Heat St202
lorrainess2
iv`e got cold air blowing from the a/c but when the temps turned up the air is only luke warm.
i`ve done a search or 2 and been told there could be air in the system or the thermostat could be faulty
can anyone give me some detailed tips on how to flush the system out and start afresh and where the thermostat is again some details on removing this
cheers
Turn the aircon off when you want warm air.
Its only there to boost cooling when its hot. Use the regular heater to get warm, only use the aircon in the summer.
Do you know how much more fuel you use when the A/C button is on? Loads. :rolleyes:
