3sgte In A Corolla
dylbachgxi
well i used st205 mounts on the chassis rails and moded st205/corolla ones for the front and rear
yes mate just finished the conversion the bottom rear mount bolts down with standard corolla mount being about 15mm higher .the bottom front i welded the gt4 mount onto subframe and moddifed both corolla upper mounts hope this helps john
