Passenger Side Leaking Camry -any Ideas?
alexmccrae
My Toyota Camry is leaking throughout the passenger foot wells of the car, the dampness only seems to be under the foot mats and is not coming in through the sun roof, has anyone experienced this problem or got a solution of where the water could be coming in from? It gets wet even when the car is parked.
Alex
Hi and welcome.
there are a few possibilities with your problem .
Coolant leaking from the heater matrix tends to get the passenger side in Toyota's,
the drain from the aircon could be blocked and overflowing, OR you've got outside weather getting in somewhere.
It's easy enough to tell if it's coolant - taste it and if it's sickly sweet then it's a coolant leak.
The drain pipe for the aircon ( I'm assuming your car has this feature ) can block up underneath the car, or can sometimes work loose and cause a puddle.
Sorry I can't really help more, but it might give you a pointer or two.
Good luck
Rich
