Debadging
kenty
Hi again,
finding myself quite addicted to this site! :P all my problems solved on one site! ;)
heres another one for you all, how easy is it to debadge and/or rebadge? is it just a case of taking them off or will i need the space painting or anything?
also, what is needed for rebadging? ive heard sillicone? :unsure:
cheers for any help! :D
Erm debadging you need, hair dryer/heat gun and some dental floss, then some car cleaning products and a strong arm!
To rebadge you will need flue of some sort...
As far as debadging goes the bonnet Badge is only one with holes in on SR! so all boot badges can be removed!
If you want to rebadge buy new badges on eBay they are like a quid, then peel the backing off and stick them on.
Debadging is easy with a hairdryer and floss but its harsh on the paint she'll need buffed afterwards.
As far as debadging goes the bonnet badge is only one with holes in on SR! so all boot badges can be removed!
Depends on what Badge you're putting on, if it's the old one or if it's a brand new. The FunCargo Badge I installed on my car was glued on the rear, just put it on straight and drive.
It's clever to wash and wax it really well where the Badge has been, yes, it will look a lot nicer then. Oh, and I found dental floss to be a real pita to work with, I ended up using fishing line.
