Helps Conectores Navi
jony83
Hello. I call jony83, am of españa, of the forum www.clubtoyota.es. am a holder of a corolla TS of the year 2005 which there goes mariner(browser) model B9004. I have been finding out on the placement of a back chamber(camera), but I do not manage to find the suitable pines. I have acquired a chamber(camera) format NTSC and have throw(add) diverse tests(proofs), on having put the reverse a message goes out on the screen: " monitor the back part of his(her,your) vehicle " but in the image one does not see anything, a few horizontal stripes go out in movement of it(he,she) arrives down(downwards). Can someone help me??
Estaria eternally grateful
PD: forgive my writing, I am not aconstumbrado to the Englishman
Hola jony83,
This does not look like the B9004 we know.
It looks like the model that sp33dy1969 did some work on.
His post is here:-
sp33dy1969 Work
I hope that helps!
sorry, In front of the browser puts B9003 :huh:
No Problem!
This is the B9003, I think. The camera connector is the white, 4 pin socket.
Let us know, if you need more help.
Thank you for the received help!
Me podrias say which are the sideburns to connecting? For what is well-read sound the sideburns 1 and 3, but I prove(try) it in my mariner(browser) and on having put the reverse, it(he,she) goes out for me " monitor the back part of his(her,your) vehicle " but they go out for me a few lines q go moving down(downwards) horizontal. This is provado with the stopped car and the put stop brake.
Habeis had(taken) the same problem? Habeis modified some kind of mas?
I am lost.
PD: I use a chamber(camera) NTSC
It is difficult for me to understand your question, but I will try.
If you can, check that your camera works OK with something else. Maybe check it with a TV that is NTSC compatible.
After, you could try connecting pin 3 to pin 4, so that GND is common.
I sit(feel) q it becomes my reading difficult, but it is what the translators have online, that are a bit bad(wrong)...
My chamber(camera) in NTSC, and it works well, she(it) is provado in the TV and one is OK..
Can sideburn join 3 with the sideburn 4 without nothing happens(passes)??
Is there necessary q to disconnect algun another cable??
Thank you again for your help
Ok, here goes....
For the b9003 you need a ntsc camera - yes.
Connect the camera to the 4 pin white socket on the rear of the unit. (the one with the red square around it in the pictures of the rear of the nav on the other post)
Make sure both the bottom two pins (3 & 4) are connected together.
the video signal from the camera then connects to pin 2 (yellow) in the picture. and the ground from the camera to pins 3 & 4 which are connected together.
note pin 1 is for powering the cam with +6 volts. don't use this if you are directly powering the cam.
hope that helps.
Picture of original camera plug....
Many thanks for helping me out Sp33dy1969!
I think jony83 problem is probably the gnds if my translation is correct, but he's got the full info now.
Thank you very much to the 2! Now I it start seeing very much clear mas.
This week will buy the conector and provare. already you ire counting, serious the first corollo/runx of españa in taking the back chamber(camera)!
Thank you very much again
Give a look at my webpage:
http://it.geocities.com/illogiko/
Fabrizio
Hello, thank you all, as I address the camera, sees a thousand wonders.
As you get any input mp3 or some kind of storage, as memories, cards or similar.
