Possible Gearbox Issue Carina E 1.8 Manual
ck6uk
hey guys new to the forum and this is my first post
after much searching through the forum i cant find any info on the problem i have:
The car seems fine on idle, but second third fourth and fifth gear, are getting like vibrating rattle but not in first. The gear stick does not vibrate and the car pulls ok as normal, reverse gear is also fine
what i need to know is, is there a seperate gear oil for the gearbox or does it use the oil off the engine?
thank for all your help!!
chris
For a drain and refill you need 2.6lt of Gear oil 75W/90 grade.
