Rav 4
igormus
hi there
please guide whether i can install 16" dics with 225 mm tyres?
the reazon is that i have hold the winter types from subaru forester for further use.
thanks/igor
Not exactly sure what sizes you have in mind. If you go into an alloy wheels shop, they'll normally be able to tell what wheel/tyre size will fit a RAV
I have 18" alloys on mine. Of course you need to make sure the offset is ok to clear the caliper. Unless you're using original wheels. Then the issue is clearance on full lock.
no
the idea is to use spare tyres as 225 mm/16" -- that is all i need to prevend additional money wasting for new tyres suitable.
thanks
