Help
Korny_Yaris
I was after a bit of help.
I have recently installed my head unit, 6x9’s, amp n subs in my T sport all working fine.
Its just the cables!
I need to tuck them away between the back of the head unit and the sills on the door unless they just hang down in the foot well. Any ideas? (passenger side)
Also the remote cable for the amp, I have it in but very loosely into the block on the back of the head unit. Any way 2 keep it lodged in? I am using the green wiring loom by the way for the 6x9’s.
Thanks.
I went driver side, but im pretty sure u can run the cables above the ECU of some sort underneath the glove compartment.
You can solder the wires together if your ok with soldering or get some spades/shovel and do it that way, I've never had my remote cable amp wire in a block becasuse generally wire is smaller than normal.
thanks loads 4 the reply,
erm ok il try and do that.
what do you do with your remote wire then?
thanks again.
Oh.. Cable ties are your friend... ^_^
You could get a male and a female of these:
or you could just strip the two wires back about 1/2 inch then wrap them together then use solder together and ele tape or you could do without solder theoretically and just tape it if your bit lazy but its better and alot more secure with solder :P
I have some of those!
and I have some of those 2! lol
thanks loads mate, I knew some1 on here would know.
Gona post pix 2nyt when I have it all sorted.
Much appreciated.
Mark.
