Aftermarket Wheel Size For Gt-four
vitzpower
Hi All,
I am looking at an aftermarket set of wheels for my Gen 6 Celica GT-Four. The wheels are 5x100 PCD, Offset Et38, 17x9J.
Will these fit?? I am concerned that the 9J may be too wide, am I right??
Quick help needed before someone else buy the wheels :D
Thanks. :thumbsup:
sorry mate but I reccomend you try them on first- ST205 (gen6 gt4) brakes are very wide and many types of wheel do not have enough clearance.
Good Luck :)
im sure the st205 is 7.5j so they should be fine.
alot depends also on the design of the spoke on the backside of the wheels , i had to use a 1mm spacer ring to clear my calipers with wheels sent out to me supposedly to fit a st205.
Thanks for the replies. I didn't bother with them in the end, as they were too wide. The ST205 will only take 7 or 8 inch width wheels.
Definitely not an easy car to buy wheels for!!
ask the st205 owners on here what wheels they have fitted is 1 answer.
