Short Shifter....
Curious if a short shifter thingy is easy to install ??
I've seen these.... how can they make it shorter to change gears...?
Very .. 30 min job ..
I've done two ..
They make it quicker by having a shorter stick and it's also moves less.
So from 1st to Reverse is about half the distance .. I can now change gears without moving my elbow.
How much are they? £100 - £200?
expensive .. it's cheaper to mod your current one ..
I suppose you can't just cut your origonal one down with a hacksaw?
almost .. get it out .. cut a few cm off it (in the middle) re-weld it and then cut and re-mount the attaching eyelet as far up as you can .. and it'll save you £100 quid ..
