Static Odometer And Trip Meter
bigP
Hi TOC,
My 95 Carina E 1.6 odometer and trip meter have stopped moving. The speedo and rev counter and all other instruments and lights work correctly.
Are the counters on this model driven by cable or electrically? I presume that the cable drive or electrical sensor (if applicable) are mounted on the gearbox.
What checks can I carry out?
Is it likely the instrument cluster has to come off?
Many thanks for any help you may be able to give me.
Cheers
  • 4 months later...
If you got a reply let me know, I have the same problem!!!
I think there is a gear set at the back that you need to replace or else the whole spedo needs replacing - try a second-hand dealer for that one
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
