Smoke From D4d D-cat
mbx
Avensis 2.2 D-cat (t-180)
year 2006
53.000km
While engine is warming up - there is a period of 10-20 seconds (as far as I have noticed) when gray (but not black!) bad-smelling smoke is clearly seen. Usually it appears when engine is half-warm and on idle or low rpm. Adding rpm amount of smoke increases but disappears in max half a minute. No affect on engine power or performance. I put the car to maintenance, but only on end December...
Right after purchase I had a problem with cold engine start - disappeared after reinstalling ECU (kind of recall, they said).
Obviously there is some bugs left in this very nice D-cat version. Does not matter I like it so much, probably I will think for a while what car to choose a next one after 1.5 years (company car).
year 2006
53.000km
hello
the possible reasons are, as follows:
- clogging of air filter;
- ratio ----- air/fuel injected --check with sutter ;
- bug with control signal to each fuel valve pilot solenoid.
pls check with above.
chers/igor
year 2006
53.000km
hello again
i do not think that the additional problem might be with cat. convertor. Normaly it serves within 70k-80k.
i have refered to mine that was changed at 75k, but it is understood each convertor has own lifetime.
cheers/igor
The problem was with air sensor - therefore the fuel/air proportion was wrong.
As it was colder and colder air every day - the less power I had (until engine got fully warm), and finnaly the system switched to check engine mode - only ~30% power left - and that happened this morning when -16C was outside!!! (not the best timing indeed...)
The issue is fixed now, we'll see if this really was the reason.
  • 1 year later...
Hello.
I'm from Romania and a have an Avensis D-Cat from Germany, second hand.
I had same problems with my car and today i had changed the air sensor.
My question for you is if that was the really problem or something else.
Please responde me on luciancioara_arad@yahoo.com
I'll really thank you.
