Yaris Wheel Bearing Question
bellymonster
Wifes 1.0 Yaris has just failed its MOT because of a dodgy wheel bearing.
Garage says it needs the whole rear wheel hub replacing because it has ABS and it is a sealed unit.
Part cost would be in the reagion of £250 + fitting.
Firstly is it true that to replace the bearing you need to replace the hub, secondly is 250 too much ?
Thanks for any advice you can give.
Matt
Yes it is true. And yeah they are flippin expencive
Fair enough, I like to be sure that the garage aint trying to pull a fast one.
Matt
Before changing it, did they try just tightening it up a nip?
Sometimes, that is enough, just for a while.
You may also think of trying a scrappy, if you know how to fit it or if they can do it for you. Might be a lot cheaper as they don't go that often. Look for a low mileage, blown engine or front end damage car. As 75% of braking is done on the front, they should be ok. :)
