Help Pls
thundergrey_23
hi guys,
im about to buy a set of team dynamics motorsport alloys, pcd100 et 45.
will these fit on my yaris t-sport ok?
main worry is the et fitment, and if it will sit and look ok.
thanks
what size are they????
45 offset will fit on a yaris but if they are 15's it will be to much, and will sit to far into the arch.
Offset for yaris is 35-45
your better off with 35-40 for 15's
38-42 for 16's and
40-45 for 17's.
If they are 17's they will be a wider wheel so they will sit in further and sit out just as much.
I have 16" rims with offset of 42 and there is only a few mm clearance between the wheel and the brake caliper.
I wouldn't even like to try offset of 45.
