Air Filter Hose
Tuned_Up_T-Sport
Hi there, does anybody happen to know the size of the intake inlet where the pipe fits, i'm after getting some silicone hose to make a short ram for my A'pexi induction kit, should make it sit just below the headlight next to the Battery for nice cool air. Might even run a cold air feed from the fog light housing. Does anyone know if its legal to have just one foglight ???
it's about 55mm on the throttle body, and the apexi is 63mm.
Depending on how your doing it you will need a 60mm piece of silicone hose, squash it down on the throttle body with a clamp, or jubilee clip, and even though the apexi is bigger than 60mm the silicone hose will be a nice tight fit on the apexi.
Once it's clamped down properly you won't need to worry about it falling off, just incase your thinking that with the throttle body being 5mm smaller than the hose.
Hi there, does anybody happen to know the size of the intake inlet where the pipe fits, i'm after getting some silicone hose to make a short ram for my A'pexi induction kit, should make it sit just below the headlight next to the battery for nice cool air. Might even run a cold air feed from the fog light housing. Does anyone know if its legal to have just one foglight ???
Don't think you have to have a front fog at all as most Yaris don't have 'em as standard. I think that the law says any light etc, must work. If you have one, one must work and so on.
LOL another one for you, what size should the breather filter be i thought they were all the same size ??
if you get a pipercross breather filter they have 3 sizes on the one filter.
but the size is 16mm
