Size Of Stock Speakers In 1995 Toyota Hilux Surf
Corey
Does anyone know the stock speaker size ?
I have a '91 and '92, which should be the same as your's. The fronts are a 4" speaker and the backs are kind of a 4.5" speaker. I just bought some 4" JL Audio Speakers the other day that dropped right in to the factory speaker baffles in the front (not all models had baffles, some just had the speaker attached to the dashbord trim but they also use 4" Speakers.) For the rear, I bought 6" Speakers and cut the holes bigger for the rear baffles. It worked out well since those rear baffles have plenty of mounting depth. Not all 4" speakers will drop right into the fronts though, due to mounting depth. If your's doesn't have baffles or if you don't want to use them, no worries on the mounting depth.
Keep well!
