Brake Pads
n0rt
Does anyone know how easy/difficult it is to change the brake pads on a 2004 Avensis?
The reason I ask is that I have owned a Honda Prelude in the past and you needed a special piston winding tool, hell of a job!!
Any info will be greatfully received... ;)
hi
as far as i 've seen -- you only need to push an actuators cylinder pictons in to release the disc/s and after to change each pad. It is understood in order to change both rear ones - you've to release the parking brake level.
i suppose having no mistake.
cheers/igor
There are pictures of the calipers on this site.
http://www.brakeparts.co.uk/
As far as I can see there isn't any grooves on the pistons. This suggests that they aren't the rewind type.
Pushing them back shouldn't therefore be a problem. If they are stiff you may be able to use a C clamp or one of these:
http://www.machinemart.co.uk/shop/product/...piston-spreader
