Cam Belt
ABITMORELIFT!
Hi all, can anyone tell me at what miles the cam belt is due and how much should it cost?
Also whats the best oil to use?
Cheers all ;)
t-sport definitely has a timing chain as opposed to a belt.. whether that is also the cam belt i don't know.
yeh cam belt timing belt its all the same thing. so basically the engine will see its life out on the original cam/timing chain
there is no cam belt it is a timing chain doesnt need to be changed i asked when i got a service done recently
its a chain,it doesnt need changing unless you can here it rattling,then may be it would be advisable to get it done,toyota told me it was good for the life of car thou.
