Phase 1 Rear Fog Lights
Marve T-Sport
I'm looking to change them both to red does anyone know where I can source these? I'm thinking mebbie Mr T can provide them perhaps?
And are they quite a doddle to fit?
Correct.
Just ask your Mr T for a LHD rear fog light.
Whereas I changed mine both to clear, and asked for a LHD Reverse light and got what I needed ;)
Correct.
Thankinyou Tom!! was it expensive? also what's the legality of it should I remove it for MOT time?!
Well i would of thought it was a bad idea personally unless your going to rewire it so the reverse light works where it would in a normal yaris, all that will happen is hen you go to reverse, the guy or girl behind will be confused at the fact your fog light is on and either cut u up a bit or plough right into u.....
