Rav T180 Automatic Washers
bomber06
I am still getting used to all the toys on my new RAV.
When the washer controls are set to OFF and not Automatic the wipers occasionally come on - is this normal?
I am concerned that there could be something wrong with the moisture sensor or the controls themselves.
Any advice would be great!
Cheers
Chris
Bomber,
It tok me a while to get used to the wipers! The wiper settings on the T180 are as follows:
Off
Auto
Slow
Fast
If you push the stalk upwards when in Off you'll get a single sweep, also if you push the stalk down to Auto (from Off) you'll get a single sweep. The sensor for the Auto wipers can be adjusted on the stalk itself (try leaving it on the least sensitive setting when it's not raining, "-" sign). If the wipers are on the Off setting, they shouldn't come on, unless you push the stalk up or have it set to Auto.
Hope that helps :D
Think it is also worth metioning that if you pull the lever to "wash/wipe" after the initial few wipes there is a pause then they do a single wipe to mop up any water left, even if not on the automatic setting.
If everything is definitely off and they still move, then there is a problem.
I can manage with a switch!
I bet bothy knows the potato trick?
