Integration Relay
tapbuster
To tapbuster, you don't say what year your car is, but you should find it located in drivers side fuse box. Just about in front of your right knee, you might find it is a multi function relay controlling other circuits.
yep just remove the lower dash panel (two screws IIRC) and i think its the blue box
To tapbuster, The relay your looking for is in interior fusebox nu 1, just below & to the right of the steernig wheel. It should be nu 1 relay which controls central locking, electric windows & a few other items that i cannot remember now. You just swap like for like. Have you had this system checked for fault with diagnostic tool-code reader??? I wouldn't go buying pricey relays without confirming your problem correctly as you have another central locking module in the same position on the passenger side which controls your double locking.
