That Odd Just tried mine again 2.0 D4D. Same test as Kingo, one press internal door release disabled ! same test again pressed lock twice same result ! Have they changed specs, Picked my car up Nov. 1st
Not that I'm aware of, maybe worth a trip into your local dealer
Kingo :thumbsup:
Here is an explaination of deadlocking
Deadlocking is a security device which enables the car to be locked in a way that the door can't be opened from inside or outside the car without disengaging the deadlock first.
If a car thief therefore wants into you car they have to climb in through a window and out the same way as the doors will not open without the correct opening procedure with the proper key or remote.
Kingo :thumbsup:
my old corsa had "deadlocks" and some theiving scum still got in through the door. made a real mess of it too. on my auris with the second press of the key fob you can hear the deadlock engaging. :)
