Lucida Starter Help!
can anyone help? my toyota lucida starter motor seems to be stuck on, it is turning over the engine as soon as i reconnect the Battery even with the ignition switched off!
any ideas greatly appreciated
Sounds like the contacts in the starter are welded together, quite famous on these models and the Hilux also. You can buy the bits required from your dealer (or us :D:) we need the model code AND chassis number to price it up for you.
Kingo :thumbsup:
