1997 Toyota Emina Speedometer And Rev Counters Are Not Working
I have a 1997 Japanese import Emina, I reciently had to have a cracked head gasket replaced. Within 24 hours the speedometer and rev counter were not working. Ant Ideas what could be wrong?
Hi am rather new to this site but I see if I can help you.
1 check for any loose connection within the engine compartment eg.loose connectors and sockets.
2 check for any kinked wires maybe they got caught and frayed during the gasket change
3 check for any broken fuses. refer to owners manual for location as there may be several fuse boxes.
A good visual inspection may solve the problem as it seems intermittant
Good luck in finding the cause.
Regards Silvio. :D
