Stuck Ignition Key
mr tiler
Hi all
I have a big problem.The ignition key is stuck in the barrel.I have stripped down the dash to try to take out the barrel but can't find a way of undoing the weird looking nuts.Does anybody have ideas
Thanx
i pm'd you .
some say d/c the batteries will also release the key . ????
i pm'd you .
Thanx very much.Did what you said worked a treat :D
Its not to do with the lock barrel, its to do with the gear selector switchs, that is why disconnecting the Battery sorts it.
