Restricted To 115
tommyd1983
Honestly why do this? I mean if your tracking on airplane runways a lot etc fairy muff but normal road usage? You will get clocked if you exceed the limits regularly enough by significant amounts, endanger yourself, endanger others, and likely cause excessive wear to your nice car.
Stay safe m8 and look after your licence... without one I imagine things get very interesting :(
Best wishes
Jinxed
its 112 mph actually
to remove it buy a derestictor off ebay . 3 or 4 wires to solder onto the back of the speedo clocks.
http://cgi.ebay.co.uk/SPEEDO-CONVERTOR-DEL...1QQcmdZViewItem
No soldering required, just need to cut the +ve -ve and gearbox signal wire going to the clocks and fit the chip which is pre-wired
  • 2 months later...
Any idea where is the cable install? I can't found the right place for install the speedo. Thanks in advances
is your car still readin in kph then or has sum1 changed the clocks? usually if the car has been converted to mph then the restrictor is removed.
i tried this, wired in at back of speedo but still limited? any ideas anyone?? pain trying to do track days and restriced to 112
have your def bought the right thing? is it a converter and de restrictor?
  • 5 weeks later...
Wanting to convert my kmh to mph ST205 do i need a converter or just cut wires or remove an existing item
many thanks
