Front Drivers Seat 3 Door
wiz
Hi
Just picked up a new Yaris SR 3 door.
Manual not clear. Should both front seats tilt and slide to gain access to rear?
Only the passenger seat tilts and slides, driver tilts only.
Also rear seat belt connections. The central one is identified but appears to be the wrong way around.
Looking from the front the RH passenger connection is on the left and the central one is on the right.
Belts cross each over when you have 3 passengers in the back.
Apart from an annoying clunk when the clutch is depressed the car is amazing.
So easy to drive, the gearbox and steering are excellent.
Any help on the questions would be greatly appreciated.
