alrite ppl.
im about to buy some new front discs and pads as they need replacing..
was just going to get stock but is there anything uprated that is about similar money that ppl recommend???
ps its a rev 2 turbo j plate.
Tas :thumbsup:
Ive been through quite a range of brakediscs in my time(on all sorts of cars) and do you know what I found out is the best setup up in the end for performance and price?? Stock discs and pads. The after market items wear rate is much higher as is the annoying warming up process(up to 15 min on cold days!) so unless you regularly hit B roads its not really worth the effort apart from the looks . So if your about the city mostly the stock setup is king imo.
I've got my Red.Dot grooved and drilled .. not for performance but looks ..
about £60 a corner ..
