Help! Offset Of Mr2 Alloys
The standard spec is as follows for the Roadster
PDC = 4x100
ET45 = offset
Bore = 54.1
PDC = 4x100
ET45 = offset
Bore = 54.1
Thank you so much for your help, it wouldnt matter if they are 16 inch instead of the standard 15?
I'm pretty sure that the facelift (2003 onward) rear 16" wheels are the same ET45 offset as the 15" post facelift (upto 2003)
If you want I can check tomorrow for you (assuming that it is stamped on the 16" wheels) as I have a set in my garage.. afraid it is too dark now and I'm have a bit of a bevvy session here ;)
If you want me to check.. post here or send me a PM.
