Lift Bolts!
ABITMORELIFT!
Hi all, hope you all had a good christmas?
Has anyone any pics of where the lift bolts are? how much are they and can they be easily replaced?
Cheers all!
If you own a phase 2 T Sport, you dont really need to worry about them.
Do a quick search, there is a thread on here with pics and prices :thumbsup:
EDIT: Just searched, found this one Lift Bolts Info
Give ian at TR&D in nottingham a call (01159680666) he will change both broken and non broken lift bolts a lot cheaper than Toyota.
Cheers for the replies fellas! i can feel lift at 6.2k but not much! is that a sign the bolts are worn?
Thanks again!
Thanks again!
Hi there, had the same problem about 4 months ago. Purchased new lift bolts (£1.10 each) and had them fitted and problem was cured! There didn't seem to be any noticable wear on the old ones but it sorted it anyway :D
Good luck mate!!
i can feel strong lift in 1st , 2nd and 3rd in my 2003 model but is it wise to get them changed any way? how much?
Thanks again!
Good luck mate!!
alright mate - what did you torque the lift bolts to? gonne do mine myself.
Hi all, where can i buy them from? or are they toyota only? are there any torque settings?
Cheers!
