Sat Nav Poi's
tccom
hi all,any of you guy's/girl's have any poi's for Shell v power stations for the uk,would stop the panic when running empty during the summer on holiday.thank's.
hi all,any of you guy's/girl's have any poi's for shell v power stations for the uk,would stop the panic when running empty during the summer on holiday.thank's.
I use this
http://checkpoint.oabsoftware.nl/
Works a treat for me with Tom Tom as I travel all over UK. You need to create an account then download the relevent POI's There are 2 options, Shell & Shell V Power, but as far s I am aware all Shell stations now dispense V Power. Be aware that some of the POI's are out of date though, may be worth double checking the shell website if you know where you are off to? Also remember the ECU reset function just in case you get stuffed.
Good Luck! :)
I use this
Good Luck! :)
hi,cheers for that.will come in very handy
