Oil And Water
tuga.4td
I swaped the engine in my surf, and now after 600 miles ive found oil all over the plce in the water system, the oil pressure switch doesnt read any pressure and im just trying to figure out what the problem is, its not the head gasket! anybody has any ideas or had similar problems? i would apreciate some help to figure out what the problem is with the engine. thanks
The most likely culprit for oil in the coolant is the oil cooler gasket. It's the part what the oil filter screws on to.
You can only get the gasket from Toyota dealers, I think.
cheers mate, i got to that conclusion with my mechanic, he says that is a comon failure with 2.4 diesel toyotas. thanks
