Corolla (2005 1.4d-4d) - Rear Wiper Replacement?
Paulq
Am really struggling to get a replacement rear wiper blade for my Corolla as none of the usual outlets appear to stock them. Anyone any idea where I can get one from and/or how much they are if I have to buy from a Toyota dealer?
Paul
Won't be much; PM Parts-King with your car details and he'll quote you.
Or consider just replacing the rubber? I doubt the blade itself is gone after only a couple of years. Probably about £5 from Toyota and again Kingo will probably give you a slightly better price than your local dealer. Or you can buy replacement rubbers on line from many sources; I used wiperblades.co.uk and they were very efficient, though packaging costs probably prohibitive if you're just buying that one component.
Got the strip off Toyota for mine,its easy to fit and not expensive,2min job. You don't need to replace the arm
