Rear Brakes On Compressor
215 compressor
just stripped rear brakes down thought i,d give them a bit of a clean up had a bit of a scraping noise .ended up taking callipers and discs of noticed handbrake shoes were quite corroded got drums of and needed a good clean up thick layer of rust stuck to shoes of the drums .they don,t get a lot of use so think they need cleaning frequently or drums will rust.fitted some red stuff brake pads in fronts other day brakes are more responsive now . :D
i had acrapin noise with mine which i mentioned when i went in for service they replaced the disc and pads under warranty
my pal has had this done on his company car also.
