Need Help With My Levin Ae111 Bz-g...
Hey, I've just got a Levin AE111 BZ-G Superstrut. Loving the car but I have a few questions which I can't seem to find the answer for online...
1. What stereo fascia adapter will fit? I can't find any for it obviously, but will one from a Celica or old Corolla fit? They seem to have clips on them though and I can't see how it'll fit into my car...
2. When I fit my stereo, how do I take the front bit of the dash out (the centre console) to be able to screw the side plates in etc. I can see there's clips at the bottom but what else do I need to undo to pull it all out?
3. Where can I buy a new bonnet? Or at least get a paint code? Can they order in paint for me over here?
4. When does the cambelt need to be changed? How can I tell if it's already been done in Japan? How much would it cost? Should I get the water pump and the tensioners done at the same time? Total cost?
5. Why's the bonnet so hard to close! :lol:
I think that's it for now... :) Thanks in advance!
www.ae111.co.uk
Hey dude, its me off djcc!
Can you get me a pic of your stereo and hole!
1) I will have to see the pic.
2) The whole black bit just pops/pulls off, then there is four screws you undo and the meatl cage comes out to take a headunit of blanking plate!
3) Not sure about this! Whats wrong with yours? The paint code for the black levin is 205 and its the same as the starlet! You can get the paint from Halfords!
4) Should be at 100,000km! There will be a sticker on the cover saying 100k, if its not here it might have been changed! You could always take the top cover off and look at the belt! Make sure there is nothing visually wrong with it! Also is there any writing on it?
Toyota say if they did the cambelt they would only do the belt! i think i will try to do the whole lot on mine though as im 17k overdue if mine hasn't been done already!
5) It shouldn't be hard, mine is quite easy! If you come to the Portland meet we can have a look!
Also make sure your car is really dirty so it makes mine look better than it is lol!
